Stat > DOE > Mixture > Response Optimizer > Setup
Specify the goal, boundaries, weight, and importance for each response variable.
Response: Displays all the responses that will be included in the optimization. This column does not take any input.
Goal: Choose Minimize, Target, or Maximize from the drop-down list.
Lower: For each response that you chose Target or Maximize under Goal, enter a lower boundary.
Target: Enter a target value for each response.
Upper: For each response that you chose Minimize or Target under Goal, enter an upper boundary.
Weight: Enter a number from 0.1 to 10 to define the shape of the desirability function.
Importance: Enter a number from 0.1 to 10 to specify the comparative importance of the response.
