1 Choose Stat > DOE > Mixture > Response Optimizer.
2 Move up to 25 responses that you want to optimize from Available to Selected using the arrow buttons. (If an expected response column does not show in Available, fit a model to it using Analyze Mixture Design.)
or
or
You can also move a response by double-clicking it.
3 Click Setup.
4 For each response, complete the table as follows:
1 If you choose Minimize under Goal, enter values in Target and Upper.
2 If you choose Target under Goal, enter values in Lower, Target, and Upper.
3 If you choose Maximize under Goal, enter values in Target and Lower.
For guidance on choosing bounds, see Specifying bounds.
5 Click OK.
6 If you like, use any of the available dialog box options, then click OK.
