Stat > Reliability/Survival > Repairable System Analysis > Nonparametric Growth Curve > Graphs
Use to create an event plot, plot of the mean cumulative function, or plot of the mean cumulative difference function.
Event Plot Check to display an event plot.
Display cost/number of repairs on event plot: Check to display the cost or number of repairs on the event plot.
Mean cumulative function: Check to display a plot of the mean cumulative function.
Mean cumulative difference function: Check to display a plot of the mean cumulative difference function. This plot is only available when you have multiple samples.
Display confidence intervals on plots: Check to display confidence intervals on the mean cumulative function and mean cumulative difference function plots. By default, Minitab plots a 95% confidence interval. You can change the confidence level in the Options subdialog box. Confidence intervals are only calculated when you have multiple systems.
Show graphs of different variables or by levels: Choose to display the graphs overlaid on the same page or on separate pages. Event plots are always on separate pages.
Minimum X scale: Enter a value for the minimum x-axis scale.
Maximum X scale: Enter a value for the maximum x-axis scale.
X axis label: Type the desired text to replace the default x-axis label with your own label.
