查看: 669|回复: 1
ISO 27427:2023 Anaesthetic and respiratory equipment — Nebulizing systems a...
发表于 2025-3-27 10:40:57 | 显示全部楼层 |阅读模式
ISO 27427:2023 《Anaesthetic and respiratory equipment — Nebulizing systems and components》
This document specifies requirements for the safety and performance testing of general-purpose nebulizing systems intended for continuous or breath-actuated delivery of liquids, in aerosol form, to humans through the respiratory system.
This document includes gas-powered nebulizers (which can be powered by, e.g., compressors, pipeline systems, cylinders, etc.) and electrically powered nebulizers [e.g. spinning disc, ultrasonic, vibrating mesh (active and passive), and capillary devices] or manually powered nebulizers. This document DOEs not specify the electrical requirements of electrically powered nebulizers.
ISO 27427-2023.pdf
2.1 MB, 下载次数: 8
售价: 30 品质币  [记录]
ISO 27427-2023.pdf
发表于 2025-3-28 15:55:10 | 显示全部楼层
GMT+8, 2026-11-26 04:39 , Processed in 0.018483 second(s), 8 queries , Gzip On, Redis On.
