查看: 848|回复: 1
IEC 62316:2017 Guidance for the interpretation of OTDR backscattering traces for
发表于 2017-8-7 23:58:02 | 显示全部楼层 |阅读模式
IEC TR 62316:2017 Guidance for the interpretation of OTDR backscattering traces for single-mode fibres
IEC/TR 62316:2017 which is a Technical Report, aims to provide guidelines for the interpretation of backscattering traces, as obtained by traditional optical time domain reflectometers (OTDRs) – not including polarization OTDRs – for single-mode fibres. Also, backscattered power effects are discussed in case of unidirectional trace. Full description of the test measurement procedure can be found in Annex C of IEC 60793-1-40:2001. This third edition cancels and replaces the second edition published in 2007. It constitutes a technical revision. This edition includes the following significant technical changes with respect to the previous edition:
a. the scope has been extended to include single-mode fibres;
b. backscattered power effects are discussed in case of unidirectional trace, including so-called losers and gainers.
c. example of apparent splice loss evaluation for unidirectional OTDR measurements has been added:
d. description of launch and tail cords have been added;
e. figures have been improved.
Publication type        Technical Report
Publication date        2017-07-12
Edition        3.0
TC/SC        TC 86/SC 86A - Fibres and cablesrss
ICS        33.180.10 - Fibres and cables
Stability date          2020
Pages        21
File size        1367 KB
发表于 2017-8-8 09:24:08 | 显示全部楼层
谢谢分享。。。
GMT+8, 2024-6-27 01:39 , Processed in 0.025551 second(s), 7 queries , Gzip On, Redis On.
