查看: 401|回复: 8
EHEDG guideline 欧洲卫生工程设计指引
发表于 2025-10-30 13:39:42 | 显示全部楼层 |阅读模式
EHEDG guideline 欧洲卫生工程设计指引(可能会涉及到版权问题)
Doc 01 Microbiologically safe continuous pasteurization.pdf
1.43 MB, 下载次数: 1
售价: 30 品质币  [记录]
Doc 02 Assessment of in-place cleanability 2004_Updated 07.pdf
390.43 KB, 下载次数: 0
售价: 30 品质币  [记录]  [购买]
Doc 03 Microbiologically safe aseptic packing of food products.pdf
1.4 MB, 下载次数: 0
Doc 04 A method for the assessment of in-line pasteurization.pdf
972.45 KB, 下载次数: 0
Doc 05 A method for the assessment of in-line steam sterilisa.pdf
415.06 KB, 下载次数: 0
Doc 06 the microbiologically safe continuous flow thermal ster.pdf
3.1 MB, 下载次数: 0
Doc 07 A method for the assessment of bacteria tightness of f.pdf
363.46 KB, 下载次数: 0
Doc 08 Hygienic Equipment Design Criteria Second Edition 2004.pdf
503.67 KB, 下载次数: 0
Doc 09 Welding stainless steel to meet hygienic requirements.pdf
2.48 MB, 下载次数: 0
Doc 10 Hygienic design of closed equipment for the processing.pdf
1.69 MB, 下载次数: 0
Doc 11 Hygienic packing of food products.pdf
1.76 MB, 下载次数: 0
Doc 12 The continuous or semicontinuous flow thermal treatmen.pdf
3.22 MB, 下载次数: 0
Doc 13 Hygienic design of equipment for open processing.pdf
2.36 MB, 下载次数: 1
售价: 30 品质币  [记录]
Doc 14 Hygienic requirements of valves for food processing1.pdf
593.83 KB, 下载次数: 0
doc 15 A method for the assessment of in-place cleanability.pdf
1008.58 KB, 下载次数: 0
Doc 16 Hygienic pipe couplings.pdf
2.36 MB, 下载次数: 0
Doc 17 Hygienic design of pumps homogenisers and dampening.pdf
1.03 MB, 下载次数: 0
Doc 18 Passivation of stainless steel.pdf
1.26 MB, 下载次数: 0
Doc 19 A method for assessing the bacterial retention ability.pdf
1.52 MB, 下载次数: 0
Doc 20 Hygienic desing and safe use of double-seat mixproof v.pdf
2.68 MB, 下载次数: 0
Doc 21 Challenge tests for the evaluation of the hygienic ch.pdf
4.51 MB, 下载次数: 0
Doc 22 Hygienic design criteria for the safe processing of dry particulate materials.pdf
662.79 KB, 下载次数: 0
Doc 23 Production and use of food-grade lubricants.pdf
753.25 KB, 下载次数: 0
Doc 24abbr_ and control of Legionella spp (Incl Legionnaires Disease) in Food Fa.pdf
839.3 KB, 下载次数: 0
Doc 25 Design of Mechanical Seals.pdf
613.49 KB, 下载次数: 0
Doc 26 Hygienic engieering of plants for the processing of dry particulate materials.pdf
720.46 KB, 下载次数: 0
Doc 27 Safe storage and distribution of water in food factor.pdf
483.21 KB, 下载次数: 0
Doc 28 Safe and hygienic water treatment in food factories_D.pdf
482.31 KB, 下载次数: 0
Doc 29 Hygienic Design of Packing Systems For Solid Foodstuf.pdf
850.12 KB, 下载次数: 0
Doc 30 Guidelines on Air handling in the food industry_Mar0.pdf
1.45 MB, 下载次数: 0
Doc 31 Hygienic Engineering of fluid bed and spray dryer pla.pdf
383.85 KB, 下载次数: 0
Doc 32 Materials of Construction_for equipment in contact wi.pdf
609.87 KB, 下载次数: 0
Doc 33 Hygienic Engineering of discharging systems for dry p.pdf
474.02 KB, 下载次数: 0
Doc 34 Integration of Hygienic and Aseptic systems, Mar2006.pdf
878.58 KB, 下载次数: 0
Doc 35 Hygienic Welding of stainless steel tubing in the foo.pdf
1.93 MB, 下载次数: 0
散修,非团队,非咨询公司,Lorin的分享资料,任何企业/组织/个人若涉及到侵权,即时联系;
77
发表于 2025-10-30 22:00:38 | 显示全部楼层
发表于 2025-10-31 01:42:09 | 显示全部楼层
发表于 2025-10-31 07:57:45 | 显示全部楼层
发表于 2025-10-31 08:01:25 | 显示全部楼层
发表于 2025-10-31 08:15:02 | 显示全部楼层
发表于 2025-10-31 08:49:55 | 显示全部楼层
发表于 2025-11-4 20:59:41 | 显示全部楼层
发表于 2025-11-5 08:05:31 | 显示全部楼层
谢谢分享。
每天进步一点点。
GMT+8, 2026-11-5 03:04 , Processed in 0.032700 second(s), 8 queries , Gzip On, Redis On.
