查看: 1027|回复: 28
GP-9 GENERAL MOTORS RUN@RATE
发表于 2025-12-30 16:25:48 | 显示全部楼层 |阅读模式
GENERAL MOTORS RUNRATE GP-9.pdf
I. PURPOSE
The purpose of a Run @ Rate is to verify:
A. the supplier's actual manufacturing process is capable of producing components that meet GM's on-goingquality requirements, as stated in the Production Part Approval Process (PPAP), at quoted tooling capacity for a specified period of time; and B. the supplier's actual manufacturing process conforms to the manufacturing and quality plan documentedby the supplier in PPAP, GP-12 and other required documentation. During a Run @ Rate, all production tooling is to be in place and running at full capacity, utilizing all regular production, direct and indirect, personnel and support systems.
II. SCOPE
All new parts require a Run @ Rate, unless exempted by the supplier quality engineer and approved by theSupplier Quality and Purchasing Directors of the procuring division.
267.7 KB, 下载次数: 29
售价: 15 品质币  [记录]
发表于 2025-12-31 07:39:39 | 显示全部楼层
发表于 2025-12-31 07:56:35 | 显示全部楼层
河北省 石家庄市
发表于 2025-12-31 08:04:16 | 显示全部楼层
发表于 2025-12-31 08:17:17 | 显示全部楼层
发表于 2025-12-31 08:20:18 | 显示全部楼层
发表于 2025-12-31 08:33:47 | 显示全部楼层
发表于 2025-12-31 08:51:43 | 显示全部楼层
GMT+8, 2026-11-5 06:04 , Processed in 0.026992 second(s), 8 queries , Gzip On, Redis On.
