查看: 1079|回复: 23
ASTM D3359-2017.pdf
发表于 2026-4-1 13:18:47 | 显示全部楼层 |阅读模式
ASTM D3359-2017.pdf Standard Test Methods for Rating Adhesion by Tape Test1
This standard is issued under the fixed designation D3359; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon indicates an editorial change since the last revision or reapproval.
This standard has been approved for use by agencies of the U.S. Department of Defend
ASTM D3359-2017
ASTM D3359-2017
ASTM D3359-2017.pdf
337.09 KB, 下载次数: 6
ASTM D3359-2017.pdf
24
发表于 2026-4-2 07:39:53 | 显示全部楼层
发表于 2026-4-2 08:11:42 | 显示全部楼层
谢谢楼主分享
发表于 2026-4-2 08:12:41 | 显示全部楼层
谢谢楼主分享
28
发表于 2026-4-2 08:24:09 | 显示全部楼层
D3359-23
D3359-23.pdf (704.33 KB, 下载次数: 7)
45
发表于 2026-4-2 08:26:01 | 显示全部楼层
发表于 2026-4-2 08:53:05 | 显示全部楼层
发表于 2026-4-2 09:11:44 | 显示全部楼层
发表于 2026-4-2 10:18:16 | 显示全部楼层
GMT+8, 2026-11-24 17:54 , Processed in 0.035224 second(s), 9 queries , Gzip On, Redis On.
