查看: 1381|回复: 26
ISO 2859-1:2026标准发布,GB/T 2828.1-2027或者GB/T 2828.1-2028标准要出
发表于 2026-4-16 23:33:30 | 显示全部楼层 |阅读模式
ISO 2859-1:2026 《Sampling procedures for inspection by attributes - Part 1: Sampling schemes indexed by acceptance quality limit (AQL) for lot-by-lot inspection》标准发布了,
ISO 2859-1-2026标准
ISO 2859-1-2026标准
The main changes are as follows:
  • a new procedure for switching from normal (or reduced inspection) to skip-lot sampling inspection has been added;
  • guidance on the requirements for producer and product qualification for skip-lot sampling inspection has been added;
  • guidance on the efficacy of implementing skip-lot sampling inspection and some methods of randomly selecting lOTS to inspect or skip has been added;
  • the operating characteristic (OC) curves for each plan have been removed in favour of sharing methods to create an individual plan's OC curve and average sample number (ASN) curve, both of which are now included in Annex E.
It is highly recommended that this document be used together with ISO 2859-0:1995, which contains illustrative examples.
主要变更如下:
  • 新增了从正常检验(或放宽检验)转换至跳批抽样检验的新程序;
  • 新增了关于跳批抽样检验对生产方及产品合格评定要求的指导说明;
  • 新增了关于实施跳批抽样检验的有效性,以及随机选取检验批或跳检批若干方法的指导说明;
  • 删除了各抽样方案的操作特性(OC)曲线,改为提供构建单个方案 OC 曲线及平均样本量(ASN)曲线的方法,上述内容现均纳入附录 E。
GBT 2828.1-2012版本,等同采用的是ISO 2859-1-1999版
强烈建议本文件与ISO 2859‑0:1995配套使用,该标准中包含示例说明。目前国内还是使用GB/T 2828.1-2012版本,等同采用的是ISO 2859-1:1999版,这也就意味着GB/T 2828.1-2012标准也会相应的升版,GB/T 2828.1-2027或者GB/T 2828.1-2028, 2029标准要颁布了。
上海市
发表于 2026-4-17 07:42:50 | 显示全部楼层
DDDDDDDDDDD
质量专家
质量总监
发表于 2026-4-17 07:42:56 | 显示全部楼层
发表于 2026-4-17 07:57:20 | 显示全部楼层
发表于 2026-4-17 08:04:42 | 显示全部楼层
发表于 2026-4-17 08:34:50 | 显示全部楼层
感谢楼主分享
发表于 2026-4-17 08:38:29 | 显示全部楼层
发表于 2026-4-17 08:45:08 | 显示全部楼层
GMT+8, 2026-11-5 07:06 , Processed in 0.030652 second(s), 7 queries , Gzip On, Redis On.
