查看: 1292|回复: 21
电子烟测试规范 Test Specifications V3.pdf
发表于 2026-6-2 15:36:36 | 显示全部楼层 |阅读模式
论坛里面的电子烟测试规范比较少,这边分享一个,这个电子烟测试规范还是很详细的。
Test Specifications for Colours Materials and Finishes (CMF) (RDNEU)
Table of contents
1 Purpose ............3
2 Scope and Applicability...............3
3 Roles and Responsibilities .........3
4 Instructions .......3
4.1 Test Application Matrix .......3
4.2 Test Sample Preparation....5
4.3 Design Verification CMF Tests (Part Level) ..............5
4.3.1 Cold & Dry Heat Test (Low temperature & High temperature) ...5
4.3.2 Damp Heat Test (High Temperature High Humidity) .....6
4.3.3 Thermal Shock Test ...7
4.3.4 Sweat Test.....9
4.3.6 Water Absorption Test...........11
4.3.7 Alcohol Resistance Test (Alcohol Rubbing Test).........12
4.3.8 Gasoline Resistance Test (Gasoline Rubbing Test) ....13
4.3.9 Coating Abrasion Resistance Test.....14
4.3.10 Logo Abrasion Resistance Test (Printing Abrasion Resistance Test) ..............15
4.3.11 Rubbing Resistance Test ....16
4.3.12 Adhesion Test (Cross-cut Test)........17
4.3.13 Rod Scratch Test....18
4.3.14 Chemical Stain Test ............19
4.3.15 Xenon-arc Radiation Exposure Test .............21
4.3.16 Colorfastness test...22
4.3.17 Packaging Vibration ............23
4.3.18 ESD ...........24
5 Reference Documents..............25
6 Related Documents .....25
7 Records ..........25
8 Revision History...........25
9 Appendix.........27
9.1 DVT Checklist......27
9.2 Sampling Size......28
Product and Process Development & Maintenance
电子烟测试规范Test Specifications V3.pdf
1.27 MB, 下载次数: 20
售价: 50 品质币  [记录]
发表于 2026-6-2 20:31:15 | 显示全部楼层
路过看看
发表于 2026-6-2 21:30:24 | 显示全部楼层
发表于 2026-6-3 07:30:55 | 显示全部楼层
发表于 2026-6-3 07:49:29 | 显示全部楼层
江苏省 无锡市 江阴市 璜土镇
发表于 2026-6-3 08:00:02 | 显示全部楼层
发表于 2026-6-3 08:28:21 | 显示全部楼层
全英文的呀
发表于 2026-6-3 08:49:58 | 显示全部楼层
GMT+8, 2026-11-24 17:45 , Processed in 0.034806 second(s), 8 queries , Gzip On, Redis On.
