查看: 606|回复: 0
IEC TS 62993:2017 1 000 V AC and 1 500 V DC, and up to 2 000 V AC and 3 000 V DC
发表于 2017-8-12 17:08:39 | 显示全部楼层 |阅读模式
IEC TS 62993:2017 Guidance for determination of clearances, creepage distances and requirements for solid insulation for equipment with a rated voltage above 1 000 V AC and 1 500 V DC, and up to 2 000 V AC and 3 000 V DC
IEC TS 62993:2017 gives guidance to technical committees which deal with equipment having a rated voltage of more than 1 000 V AC and up to 2 000 V AC, or a rated voltage of more than 1 500 V DC and up to 3 000 V DC. Rated voltages up to 1 000 V AC and 1 500 V DC, as well as higher or lower internal voltages, are covered by IEC 60664-1.
This document applies to equipment for use up to 2 000 m above sea level, and provides guidance for use at higher altitudes.
This document gives guidance for clearances, creepage distances and solid insulation for equipment to achieve safety. It includes methods of electric testing.
Publication type        Technical Specification
Publication date        2017-07-12
Edition        1.0
TC/SC        TC 109 - Insulation co-ordination for low-voltage equipmentrss
ICS        29.080.30 - Insulation systems
Stability date          2020
Pages        28
File size        1212 KB
GMT+8, 2024-6-27 09:21 , Processed in 0.055196 second(s), 7 queries , Gzip On, Redis On.
