查看: 9354|回复: 26
USB充电器测试标准USB Charger test standard
管理员
发表于 2017-8-15 15:03:40 | 显示全部楼层 |阅读模式
USB充电器测试标准USB Charger test standard ---  这个帖子,原来是2011年7月14日发的,现在转到新的论坛。
1. Apply Scope(适用范围)..
2. Quote Criterion(引用标准) .
3. Electrical characteristic (电气特性)
4. Input Characteristics(输入特性)
4.1 Rated Input Voltage(额定输入电压)
4.2 Input Voltage Range (输入电压范围)
4.3 Input Frequency (输入频率).
4.4 Input Frequency Range ( 输入频率范围).
4.5 Input AC Current(AC 输入电流)
4.6 Inrush Current ( 峰值输入电流)
4.7 Efficiency(效率)
5. Output Characteristics(输出特性).
5.1 Rated Output Voltage(输出额定电压)
5.2 Output Voltage (输出电压).
5.3 Rated Output Current (额定输出电流)
5.4 Rated Power ( 额定功率) .
5.5 LED Indicate Function (LED 指示功能)
5.6 Charger output Voltage/Current characteristics(充电器输出电压/电流特性图)
5.7 Ripple and Noise ( 输出纹波、噪音)
5.8 Current Ripple and Noise ( 输出电流纹波、噪音) .
5.9 Turn On Delay Time(启动延时).
5.10 Turn-Off Delay (关断时延)
5.11 Overshoot(过冲)
5.12 Counter current(电流倒灌) .
5.13 Protection(保护)
5.13.1 Over Voltage Protection(过压保护)
5.13.2 Over Current Protection(过流保护) 5
5.13.3 Short Circuit Protection(短路保护) 5
6. Reliability Items ( 信赖性项目) .
6.1 ElectroStatic discharge (静电).
6.2 Hi-Pot Test (高压测试)
6.3 Insulation Resistance (绝缘电阻).
6.4 Leakage Current ( 泄漏电流) .
6.5 Temperature Rise (温升)
6.6 Continuous Working (连续工作时间) .
6.7 Mean Time Between Failure (平均无故障时间) .
6.8 EMI Standards (EMI 标准) .
7. Environmental Requirement (环境要求).
7.1 Operating Temperature ( 工作温度).
7.2 Storage Temperature (储藏温度)
7.3 Operating Humidity (工作湿度) .
7.4 Storage Humidity (储藏湿度) .
8. Mechanical Requirement (机械要求)
8.1 Dimension(尺寸).
8.2 Weight(重量)
8.3 Input plug type(输入插头类型)
8.4 USB Plug Type(USB 接口类型).
8.5 USB Plug Test(USB 接口测试)
8.6 Drop Test (跌落试验).
8.7 Vibration Test Requirement (振动试验).
8.8 Plug in and out Test (插拔实验).
8.9 Salty Fog Test for Metal part (五金件盐雾实验).
9. Mechanical Characteristics (机械性能) .
9.1 Appearance (外观)
9.2 Case/Resin materials (外壳材质)
10. Environmental Performances(环境性能).
10.1 Operating at the lower temperature (低温工作实验)
10.2 Operating at the high temperature(高温工作实验) .
10.3 Storage at the lower temperature (低温存储)
10.4 Storage at the higher temperature (高温存储)
10.5 Operating at the invariable temperature and invariable humidity (恒温恒湿工作)
945
管理员
 楼主| 发表于 2017-8-15 15:04:41 | 显示全部楼层
8.1 Dimension(尺寸)
59(L) * 27.5(W) *76(H) mm maximum
8.2 Weight(重量)
50g±5g
Wall-mount EU type. 2 Conductors, < Live. Neutral > (欧式AC 输入2PIN 插头)
Plug: Big 4pin USB (大 4pin USB)
Pin 2,3 Short;Pin2,1 and Pin 2,4 disconnection (Pin 2,3 短路; Pin2,1 and Pin 2,4 断开)
Drop the charger from a height of 100cm onto a hardwood floor, hitting the charger for 6 times,
no mechanical damages or other failures, no electrical deterioration and other failures
comparing to before test condition.
(制品从100cm 处落下6 次,落下的方向任意,落在硬地板上,实验后与实验前状态比较没有机
械破损等不良状况,且不出现电器性能损坏)
Non-operating, with packing) Reference to IEC publ. 68-2-6
(在包装好不工作的情况下实验,具体参照IEC publ. 68-2-6 标准)
Test conditions(测试条件) Acceptance Criteria(规格)
Frequency(振动频率) 10~55Hz
Sweep (振动方式) 2hours, For each axis(X,Y, Z)
Acceleration(加速度) 5.0G (5~50Hz, peak-peak)
Displacement(振幅) 0.35 mm(10~55Hz)
Nominal functional test should be
satisfied after the test
(不发生功能损坏的异常情况)
After plug the connector in(30N max) and out(10-50N) the female-connector for 10 times, then
plug in and out for 3000 times, light damage in the mechanic characteristic, but no abnormality
in electric characteristic.
(插头与连接器经正常插拔10 次,插头每次插入力度不大于30N,拔出在10-50N 之间后持续
拔插3000 次,外观允许有轻度损伤,但导通性能良好)
Experiment condition, Salty water thickness: 5%, Equipment Temperature: 35~40℃,
put the charger(unpacking)in the test equipment for 48h, after 48h recovery at 25℃ checking
the appearance, the metal parts have no erode and rust.
(盐雾试验要求:调制(工业盐)盐水的浓度为5%,设备温度设置为35~40℃,充电器不包
装,放入盐雾试验设备中持续喷雾48 小时,试验结束后取出,在常温下搁置48 小时,再检查
充电器外观;要求外露金属及电镀件不生锈。)
945
管理员
 楼主| 发表于 2017-8-15 15:03:57 | 显示全部楼层
This specification just bee applied for one model USB charger, not for all.
本规格适用于某一个型号的USB充电器,不是针对所有的.
EN55022
EN60950
YD/T 1591-2006
Test Circuit (测试电路)
If the test is to be made on a specified circuit, be sure to use the following circuit.
(无特殊规定的情况下依照下面的电路进行测试.)
945
管理员
 楼主| 发表于 2017-8-15 15:04:07 | 显示全部楼层
It is normal for 100Vac to 240Vac input AC voltage.
( 额定输入交流100V~240V)
The charger shall operate from 90Vac to 264Vac and the range switching is unnecessary.
(输入电压范围交流 90 V~264V)
AC-Charger
交流
It is normal for 50Hz or 60Hz and single phase.
(输入频率50Hz/60Hz)
The charger shall operate with an input frequency from 47Hz to 63Hz.
(输入频率范围47 Hz~ 63 Hz)
Maximum steady state input current is less than 0.15A rms. Measured at 90Vac input and
maximum load.
( 90V 满载时输入电流小于0.15Arms)
With cold starting, the inrush current should less than 30A.
( 电源启动时最大峰值输入电流小于30A)
4.7 Efficiency(效率)
50% min. measured at 100Vac to 240Vac input voltage, maximum load and include the DC
cable loss.
(在输入电压100 ~240Vac,输出最大负荷下,充电器工作效率大于50%)
945
管理员
 楼主| 发表于 2017-8-15 15:04:16 | 显示全部楼层
The rated output voltage is specified at 5.0V±0.2V
(额定输出电压范围5.0V±0.2V)
No load voltage (空载输出电压): 4.8V ~ 5.2V
Full load voltage (满载输出电压): 4.8V ~ 5.2V
The output current will be performed from 500mA±50mA at CV mode.
(在CV 模式下典型额定输出电流500mA±50mA,最大输出电流范围为450~550mA)
This Charger is capable to support 2.5 Watts continuously at all specified conditions.
(不同状态下输出功率在2.5W)
Charging: Green
Full: Green
Note: the test shall be made under the following conditions, unless otherwise specified:
Ambient Temperature 25°C, Relative Humidity 35~85%RH
Air Pressure 86~106kPa
(在无特别指定条件下,测试温度为25°C、湿度为35~85%RH、气压为86~106kPa)
Ripple voltage is 100 mV p-p (Full load 450mA) measured methods:
Performed by 20MHz bandwidth in oscilloscope
Applied 0.1uF ceramic capacitor and 10uF electrolytic capacitor across output connector
terminals Measured at the end of DC cable.
( 输出端并0.1uF 与10uF 电容,限制示波器带宽20MHz 时,测得纹波小于100mV p-p)
Current ripple is less than 100mA p-p (I=450mA) Measured methods:
(负载为450mA 测得电流纹波小于100mA p-p)
The charger is in regulation within 0.1second after specified rated input voltage had been
applied.
(在额定输入电压下充电器应该能正常启动延时时间小于0.1 秒)
The voltage reach down to 2V at CC or CV mode less than 1S after turned off.
(在CC 或CV 模式下,关断后一秒内电压降到2V 以下)
5.11 Overshoot(过冲)
When the charger switches between CC mode and CV mode, the output overshoot current
must be stable in normal range(10%) within 10mS after charging mode changed.
(充电器在CV 模式转换时,充电器在10ms 内波动范围不得超过正常10%)
Under any condition .whether the charger is connecting to the power supply the current flow
from mobile phone to charger should be less than 5mA.
(在任何情况下,不论充电器是否插在电源上,由手持机侧流向充电器的电流应不大于5mA)
5.13 Protection(保护)
The charger will be automatically self-limited while any component(s) failure and output
voltage will be tripped and protected below 6.8V±0.5V the charger can’t work after the
protection.
(当元件失效或输出电压超过6.8V±0.5V 时,充电器自动保护,保护后不可恢复)
Output current will be limited and less than 550mA Max
(输出过流保护电流:550mA Max)
The charger is protected that a short happened between the output terminals and shall not
result in a fire hazard, any damage to this Charger and will be normal operation
automatically while the short is removed. The maximum short current is 550mA Max.
(输出短路后不损坏该制品,短路恢复正常输出, 输出短路电流550mA Max)
945
管理员
 楼主| 发表于 2017-8-15 15:04:26 | 显示全部楼层
6.1 Electrostatic discharge (静电)
At 150pF:330Ω, for each point, 10 shots of direct discharge or air discharge (1 MΩ/ SHOT),
have no malfunction. Direct discharge: ±8kV, Air discharge: ±15kV
(在接触放电±8kV 和空气中放电±15kV 模式下,各处分别放电10 次无误动作)
After AC 3000V 1min between input plug-DC plug. cutoff current 5mA, the charger have no
failures like damages, arch, insulation damage etc.(at 25°C)
(在25°C 环境下,AC 输入插头与DC 插头之间加AC3000V 1 分钟,电流 5mA 最大,
充电器无损伤、电弧放电、绝缘破坏等异常)
At 25°C after DC 500V 1min between input plug- DC plug,insulation resistance 7MΩ min)
(在25°C 环境下,AC 输入插头与DC 插头之间输入DC500V1 分钟后绝缘阻抗在7MΩ 以上)
0.25mA maximum, at nominal AC input voltage and frequency
(输入时泄漏电流不得0.25mA max)
At 30℃ with the rated input 100-240Vac charged to the primary a rated load (Lout=450mA) on
the secondary, every parts of the case surface rise 55℃ or less.
(在常温30℃下输入端施加100-240Vac 电压,输出450mA 负荷的状态下,外壳表面所有地方
55℃ 以下)
With the rated voltage charged to the primary and output current 450mA, after continuously
work 96 hours have no damage.
(在输入额定电压和输出电流450mA 的条件下,连续工作96 小时,不损坏充电器。)
The charger shall be designed and produced to have a mean time between failures (MTBF) of
50000 operating hours 90% confidence-level while operating under the following conditions:
80% maximum load at 25℃, nominal input voltage. Standard: MIL-HDBK-217F
(该充电器在25℃正常输入时,输出为80%最大负载,90%情况下其平均无故障时间为50000 小时)
Designed to meet EN55022 Class B
945
管理员
 楼主| 发表于 2017-8-15 15:04:32 | 显示全部楼层
-5°C TO +40°C
-25°C TO +70°C
35~85% RH. Non-condensing
5 ~ 95% RH. Non-condensing
945
管理员
 楼主| 发表于 2017-8-15 15:04:48 | 显示全部楼层
9.1 Appearance (外观)
Visual inspection the case have no visual abnormality, no obvious nick, burr and other
mechanical damage, outer metal have no rust. Use limit sample to check for any failures.
(目视检查,无外观异常,表面无明显划痕、毛刺及其它机械损伤,外露金属部分无锈,其它
限度根据样品确认。)
Flame resistance applies to UL94V-0 or more (耐燃性遵循UL94V-0 以上)
945
管理员
 楼主| 发表于 2017-8-15 15:04:57 | 显示全部楼层
At-5±3℃, with the rated voltage 100V~240Vac charged to the primary and unloaded and
full load on the secondary 4 hours, no abnormality in electric and mechanical characteristic.
(环境温度-5±3°C,在输入端施加额定电压100V~240Vac 输出端空载与满载状态下工作4 小
时,无特性异常)
At 40±2℃, with the rated voltage 100V~240Vac charged to the primary and unloaded and
full load on the secondary 4 hours,. No abnormality in electric and mechanical characteristic.
(环境温度40±2℃,在输入端施加额定电压100V~240Vac 输出端空载与满载状态下工作4
小时,无特性异常)
At -25±3℃, test of non-operated 16 hours, No abnormality in electric and mechanical
characteristic after 2 hours recovery at the room temperature.
(在-25±3℃非工作状态下进行试验16 小时,试验后常温放置2 小时后测试无异常)
At 70±2℃, test of non-operated 16 hours, No abnormality in electric and mechanical
(在70±2℃非工作状态下进行试验16 小时,试验后常温放置2 小时后测试无异常)
At 40℃,90~95%RH, test of operating 48 hours , no abnormality in electric and mechanical
characteristic.
(在40℃,90~95%RH,非工作状态下进行试验48 小时,无特性异常)
发表于 2018-5-25 16:00:12 | 显示全部楼层
At ...
GMT+8, 2026-11-24 18:31 , Processed in 0.026835 second(s), 6 queries , Gzip On, Redis On.
