查看: 688|回复: 0
IEC 60079-1:2014 ed7.0 Explosive atmospheres - Part 1: Equipment protection b...
管理员
发表于 2017-8-22 10:25:07 | 显示全部楼层 |阅读模式
IEC 60079-1:2014 ed7.0 Explosive atmospheres - Part 1: Equipment protection by flameproof enclosures "d"
Publication date        2014-06-27
IEC 60079-1:2014 ed7.0 contains specific requirements for the construction and testing of electrical equipment with the type of protection flameproof enclosure "d", intended for use in explosive gas atmospheres.
This standard supplements and modifies the general requirements of IEC 60079-0. Where a requirement of this standard conflicts with a requirement of IEC 60079-0, the requirement of this standard will take precedence.
This seventh edition cancels and replaces the sixth edition, published in 2007, and constitutes a technical revision. The numerous changes are identified in the Foreward of the document.
Keywords: flameproof enclosure "d", explosive gas atmospheres
Technical Committee        31 - Equipment for explosive atmospheres
ICS Codes        29.260.20         Electrical apparatus for explosive atmospheres
Stability date        2017
GMT+8, 2024-6-27 03:16 , Processed in 0.024713 second(s), 7 queries , Gzip On, Redis On.
