查看: 2765|回复: 7
IEC 60598-1:2014+AMD1:2017 Luminaires Part 1: General requirements and tests
发表于 2017-9-23 10:46:06 | 显示全部楼层 |阅读模式
IEC 60598-1:2014+A1:2017 specifies general requirements for luminaires, incorporating electric light sources for operation from supply voltages up to 1 000 V. The requirements and related tests of this standard cover: classification, marking, mechanical construction, electrical construction and photobiological safety.
This eighth edition cancels and replaces the seventh edition published in 2008.
This edition constitutes a technical revision and includes the following significant technical changes with respect to the previous edition:
a) requirements to support the construction methods for new LED luminaires entering the market;
b) photobiological requirements extended;
c) more precise requirements for insulation between different types of electrical circuit;
d) other general updates and improvements.
The contents of the corrigenda of October 2015, of December 2015, of May 2017 and interpretation sheet 1 of May 2016 have been included in this copy. This consolidated version consists of the eighth edition (2014) and its amendment 1 (2017). Therefore, no need to order amendment in addition to this publication.
参与人数 1品质币 +1 收起 理由
ACHRAF + 1
GMT+8, 2025-4-7 07:30 , Processed in 0.055836 second(s), 22 queries , Gzip On, Redis On.
