查看: 1179|回复: 1
IEC 60068-2-52:2017 Part 2-52: Test Kb: Salt mist, cyclic sodium chloride soluti
发表于 2017-11-12 18:18:49 | 显示全部楼层 |阅读模式
IEC 60068-2-52:2017 Environmental testing - Part 2-52: Tests - Test Kb: Salt mist, cyclic (sodium chloride solution)
IEC 60068-2-52:2017 specifies the application of the cyclic salt mist test to components or equipment designed to withstand a salt-laden atmosphere as salt can degrade the performance of parts manufactured using metallic and/or non-metallic materials. This third edition cancels and replaces the second edition published in 1996. This edition constitutes a technical revision. This edition includes the following significant technical changes with respect to the previous edition:
- the entire content has been harmonized with ISO 9227 as far as possible;
- an introduction has been added;
- the scope has been simplified;
- normative references have been updated;
- the general description of the test has been changed;
- a dry chamber has been added to the test apparatus;
- severities have been changed to test methods;
- test methods 7 and 8 have been added;
- information on the test report has been added;
- Figure 1 has been changed to Table 1;
- a typical test apparatus example has been added in a new Annex A;
- a description of each test method has been added in a new Annex B;
- bibliographical references have been added.
重庆市 南岸区
发表于 2026-1-8 11:46:16 | 显示全部楼层
不可分享全文吗?
GMT+8, 2026-11-4 17:24 , Processed in 0.020239 second(s), 6 queries , Gzip On, Redis On.
