查看: 729|回复: 0
IEC 62489-1:2010+AMD1:2014+AMD2:2017 Electroacoustics - Audio-frequency inductio
发表于 2017-12-11 19:36:33 | 显示全部楼层 |阅读模式
IEC 62489-1:2010+AMD1:2014+AMD2:2017 Electroacoustics - Audio-frequency induction loop systems for assisted hearing - Part 1: Methods of measuring and specifying the performance of system components
IEC 62489-1:2010+A1:2014+A2:2017 applies to the components of audio-frequency induction-loop systems for assisted hearing. It may also be applied to such systems used for other purposes, as far as it is applicable. This standard is intended to encourage accurate and uniform presentation of manufacturers' specifications, which can be verified by standardized methods of measurement.
It is intended for type testing. The components considered are the following:
- amplifiers;
- microphones;
- other components, such as playback equipment.
IEC 62489-1:2010 DOEs not deal with safety, for which IEC 60065 applies. It also does not deal with EMC (Electromagnetic compatibility) and EMF (Electromagnetic fields, in the context of human exposure). This consolidated version consists of the first edition (2010), its amendment 1 (2014) and its amendment 2 (2017). Therefore, no need to order amendment in addition to this publication.
GMT+8, 2024-5-5 00:57 , Processed in 0.050714 second(s), 5 queries , Gzip On, Redis On.
