查看: 818|回复: 0
IEC 62893-2:2017 Charging cables for electric vehicles for rated voltages up ...
发表于 2017-12-11 19:43:02 | 显示全部楼层 |阅读模式
IEC 62893-2:2017 Charging cables for electric vehicles for rated voltages up to and including 0,6/1 kV - Part 2: Test methods
IEC 62893-2:2017(E) specifies test methods which are particular for cables with extruded insulation and sheath having a voltage rating of up to and including 0,6/1 kV AC or up to and including 1 500 V DC for flexible applications under harsh conditions for the power supply between the electricity supply point or the charging station and the electric vehicle (EV).
GMT+8, 2024-5-2 18:12 , Processed in 0.032739 second(s), 5 queries , Gzip On, Redis On.
