查看: 654|回复: 0
IEC 61196-1-303:2018 Part 1-303: Test for silver and tin plating thickness
发表于 2018-1-16 17:51:09 | 显示全部楼层 |阅读模式
IEC 61196-1-303:2018 Coaxial communication cables - Part 1-303: Mechanical test methods - Test for silver and tin plating thickness
IEC 61196-1-303:2018(E) defines the requirements for measuring the plating thickness for silver and tin conductors for coaxial cables used in analogue and digital communication systems.
This test method uses a procedure for determining the plating thickness of silver and tin coatings on conductors by galvanic reMOVal (coulometric method).
Publication date        2018-01-09
Edition        1.0
TC/SC        TC 46/SC 46A - Coaxial cablesrss
ICS        33.120.10 - Coaxial cables. Waveguides
Stability date          2020
GMT+8, 2024-9-21 08:06 , Processed in 0.024353 second(s), 5 queries , Gzip On, Redis On.
