查看: 708|回复: 0
IEC 60728-2:2018 Part 2: Electromagnetic compatibility for equipment
发表于 2018-1-18 20:48:03 | 显示全部楼层 |阅读模式
IEC 60728-2:2018 Cable networks for television signals, sound signals and interactive services - Part 2: Electromagnetic compatibility for equipment
IEC 60728-2:2018(E) applies to the radiation characteristics and immunity to electromagnetic disturbance of EM active equipment (active and passive equipment) for the reception, processing and distribution of television, sound and interactive multimedia signals as dealt with in IEC 60728-3, IEC 60728-4, IEC 60728-5 and IEC 60728-6.
This document covers the following frequency ranges:
- disturbance voltage injected into the mains: 150 kHz to 30 MHz;
- radiation from active equipment: 5 MHz to 25 GHz;
- immunity of active equipment: 150 kHz to 25 GHz;
- screening effectiveness of passive equipment: 5 MHz to 3,5 GHz.
This document specifies requirements for maximum allowed radiation, minimum immunity and minimum screening effectiveness and describes test methods for conformance testing.
This third edition cancels and replaces the second edition published in 2010. This edition constitutes a technical revision.
GMT+8, 2024-9-21 03:17 , Processed in 0.020826 second(s), 5 queries , Gzip On, Redis On.
