楼主: wangbin
汽车主流客户特殊特性及其控制方法:通用KCDS, 福特CC/SC/HIC/PTC
发表于 2023-4-2 20:27:34 | 显示全部楼层
Note:
Pass Through Characteristics (PTC) are defined as:
Product Characteristics that are supplied to receiving
Ford Plants by an outside supplier or by an internal
(Ford) supplier that are not controlled by subsequent
processing of the using plant. Defective PTCs may affect
Vehicle Operations or the buying public. Use of pass
through characteristics is typically required by
Powertrain.
注:传递特性( Pass through Characteristics) 的定义:
是指由外部供应商或福特內部供应商对福特工厂所提
供的,但不被使用工厂的下道工序所控制的产品特性
,不良的传递特性 ( 可能会影响到福特装配厂或
希望像水一样坚强
GMT+8, 2026-11-26 11:24 , Processed in 0.026576 second(s), 5 queries , Gzip On, Redis On.
