查看: 4668|回复: 7
ECRS stands for Eliminate, Combine, Rearrange, and Simplify.
发表于 2021-6-8 15:40:13 | 显示全部楼层 |阅读模式
ECRS stands for Eliminate, Combine, Rearrange, and Simplify. This Lean technique is primarily used to reduce or remove wasteful steps entirely from anything regarding manufacturing processes or even office procedures. It might even be helpful to put together a value stream map as well to identify necessary and complex steps within production lines. When implementing ECRS, complex and time-consuming tasks are reviewed with the goal of successfully applying any one or all of the strategies in the ECRS acronym. The end result aims to streamline any process for workers and create a more efficient business as a whole. The four methods are:
  • Eliminate – Identify the steps in a process that can be eliminated without decreasing production value. Ask questions such as:
    • Can we eliminate the root cause?
    • What is the problem with this situation currently?
    • Do we need a new process?
  • Combine – If nothing can be eliminated, see if any steps can be combined. Ask questions such as:
    • Can the same person do both steps?
    • Can we merge this step with another?
  • Rearrange – Rearranging steps may make the process faster, easier, or safer. Ask questions such as:
    • Is this the best sequence of progression?
    • Can we rearrange the process steps, process flow, or training?
  • Simplify – Simplifying steps can make complicated tasks much easier to understand. For example, this can be done by providing visual aid or better equipment. Simplifying a process has the potential to improve completion times and improve accuracy. Ask questions such as:
    • Why do we need this detail?
    • What is the objective of the process?
    • How do others do it?
31
发表于 2021-6-9 16:18:29 | 显示全部楼层
搞个英文版的
GMT+8, 2026-11-4 20:50 , Processed in 0.036848 second(s), 5 queries , Gzip On, Redis On.
