查看: 5384|回复: 5
ASTM F1249-202_Standard Test Method for Water Vapor Transmission Rate Through...
发表于 2021-9-22 09:28:12 | 显示全部楼层 |阅读模式
ASTM F1249-20_Standard Test Method for Water Vapor Transmission Rate Through Plastic Film and Sheeting Using a Modulated Infrared Sensor
ASTM F1249-20_Standard Test Method for Water Vapor Transmission Rate Through Pla.pdf
733.68 KB, 下载次数: 8
售价: 50 品质币  [记录]
GMT+8, 2026-11-24 18:08 , Processed in 0.031289 second(s), 8 queries , Gzip On, Redis On.
