查看: 14468|回复: 33
动力电池-设计规格书,分享给需要的朋友参考
发表于 2022-2-9 14:12:46 | 显示全部楼层 |阅读模式
Scope 适用范围 This specification describes the basic performance, technical requirement, testing method ,warning and caution of the Li-ion rechargeable battery pack, the pack defined in this documentation is an assembly which include battery, PCM and wire, the specification only applies to the Li-ion battery produced by Icon Energy System (Shen Zhen) Co; Ltd. 本标准规定了锂离子可充电池的基本性能、技术要求、测试方法及注意事项,电池组合定义的是包括电芯,保护板和连接线的组合,本标准只适用于博科能源系统(深圳)有限公司所生产的锂离子电池。
1.Modified List 修订履历 .... 3
2.Scope 适用范围 ....... 4
3.Battery Pack specifications 电池组规格书 ....... 4
4.Battery Appearance 电池组外型图 ........ 6
5. battery performance 电池性能 .............. 8
6.Standard environmental test condition 标准测试环境 ........ 10
7. Battery Required Protection Functions 电池组保护功能要求 ..... 11
8.Battery Packing Diagram 电池包装图 ............ 13
9.Battery charging 电池充电 ........ 14
10. Storage and Others 储存及其它事项 .... 14
11. Warranty period& Product Liability 保质期及产品责任 ..... 14
12.Labels on the battery package 包装电池上的标识 .......... 14
13.Cautions in using battery 电池使用时警告事项及注意事项 ....... 15
14. FCC specifications FCC 说明书 ...... 17
15.Free-responsibility declaration 免责声明 ..... 17
动力电池_设计规格书.pdf
783.68 KB, 下载次数: 80
售价: 12 品质币  [记录]
动力电池_设计规格书.pdf
39
上海市
发表于 2022-2-9 22:49:09 | 显示全部楼层
动力电池循环指标很重要,没有列出?
顾
发表于 2022-2-9 23:00:28 | 显示全部楼层
GMT+8, 2026-11-5 03:19 , Processed in 0.120018 second(s), 6 queries , Gzip On, Redis On.
