查看: 8937|回复: 8
[泰国] 泰国家用洗衣机的工业标准 TIS 1462-2562 能效要求已执行
发表于 2022-4-7 22:06:43 | 显示全部楼层 |阅读模式
泰国工业部于 2021 年 1 月 26 日发布制定关于家用洗衣机的工业标准 TIS 1462-2562 - 能效要求。该标准涵盖家用和类似用途的洗衣机,额定电压不超过 250 V 的单相交流电源,带或不带加热装置以及热水和/或冷水供应,标准洗涤容量不超过 30 公斤。
该标准于 2022 年 2 月 27 日起强制执行。
Issued on 26 January 2021 by the Thai Ministry of Industry, this Announcement establishes Industrial Standard TIS 1462−2562 on Washing Machines for Household Use - Energy Efficiency Requirements in accordance with the Industrial Product Standards Act.
The standard covers clothes washing machines for household and similar purposes, with rated voltage not exceeding 250 V for single-phase AC supply, with or without heating devices and for hot and/or cold water supply, having standard washing capacity not exceeding 30 kg. It also deals with appliances for water extraction by centrifugal force and is applicable to appliances for both washing and drying textile.  Excluded from the scope are washing machines for industrial use and washing machines used in special or unusual conditions such as environmental conditions that are corrosive or potentially explosive.
The standard will be mandatory with effect from 27 February 2022.
GMT+8, 2026-11-4 19:55 , Processed in 0.027044 second(s), 6 queries , Gzip On, Redis On.
