查看: 7286|回复: 3
Air Conditioner incorporating Flammable Refrigerant or low flammable refrigerant
发表于 2023-1-11 19:16:02 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
Air Conditioner incorporating Flammable Refrigerant or low flammable refrigerant (Level 2)
An electrical appliance that –
  • is for household use; and
  • incorporates motor compressors; and
  • is an electrical appliance designed to provide delivery of conditioned air to an enclosed space, room or zone; and
  • includes a refrigeration system for cooling, heating or dehumidifying the air, including hydronic room fan coil type systems; and
  • is portable, transportable or fixed; and
  • uses refrigerant having a flammability classification of Class 2 or Class 3 in accordance with ISO 817. For refrigerant blends that have more than one flammability classification, the most unfavourable classification is taken.
Class specification: AS/NZS 60335.2.40
含有易燃制冷剂的空调或低易燃制冷剂(2 级)一种电器,符合以下条件:
  • 供家庭使用;和
  • 包含电机压缩机;和
  • 是一种电器,旨在向封闭的空间、房间或区域提供调节空气;和
  • 包括用于冷却、加热或除湿空气的制冷系统,包括水力室风机盘管式系统;和
  • 便于携带、运输或固定;和
  • 使用符合 ISO 817 的可燃性分类为 2 类或 3 类的制冷剂。对于具有多个可燃性分类的制冷剂混合物,采用最不利的分类。
类规范:AS/NZS 60335.2.40
GMT+8, 2026-11-24 17:37 , Processed in 0.026569 second(s), 7 queries , Gzip On, Redis On.
