查看: 5774|回复: 16
汽车减振器常见名称中英文
发表于 2024-1-2 12:12:55 | 显示全部楼层 |阅读模式
1. 悬架滑柱总成:suspensionstrut assembly
2. 弹簧减振器总成:springshock absorber assembly
3. 支柱减振器总成:damperstrut assembly
4. 减振器总成:shockabsorber assembly
5. 复原导向总成:reboundguiderassembly
6. 贮油缸总成:outer tube assembly
7.活塞杆总成:pistonrod assembly
8. 导向座总成:guide assembly
9. 复原阀总成:rebound valve assembly
10.  工作缸及压缩阀总成:inner tube andcompression valve assembly
11.  压缩阀总成:compression valve assembly
12.  上支撑总成:top mounting assembly
13.  转向轴承:steering bearing
14.  导向座:guide
15.  活塞:piston
16.  压缩阀座:compression valve seat
17.  流通阀限位器:intake valve stopper
18.  复原阀限位器:rebound valve stopper
19.  浮动复原阀:floatingrebound valve
20.  复原阀片:rebound valve disc
21.  压缩阀片:compression valve disc
22.  流通阀片:intake valve disc
23.  补偿阀片:compression valve disc
24. 流通节流阀片:intakeorifice valve disc
25.  复原节流阀片:rebound orifice valvedisc
26. 补偿节流阀片:compensationorifice valve disc
27.  压缩节流阀片:compression orificevalve disc
28.  复原阀垫片:reboundwasher
29.  压缩阀垫片:compressionwasher
30.  压缩阀限位器:compressionvalve stopper
31.  限位器类零件:partsof limiting stopper
32.  流通阀弹簧片:intakevalve spring disc
33.  滑动轴承:slidingbearing;bush
34.  复原阀弹簧:reboundvalve spring
35.  螺旋弹簧(悬架用):coilspring
36.  缓冲阀弹簧:buffervalve spring
37.  贮油缸底座:cylinderbase
38.  止动圈:stopperring
39.  弹簧下座:lowerspring seat
40.  弹簧上座:upperspring seat
41.  卡帽:topcap
42.  定位支架:positioning bracket
43.  软管支架:hosebracket
44.  稳定器支架:stabilizerbracket
45.  油封:oil seal
46.  导向密封环:guideseal ring
47.  活塞杆:piston rod
48.  工作缸: inner tube
49.  贮油缸:outer tube
50.  防尘罩:dustcover
51.  吊环:mount ring
52.  活塞螺母:pistonnut
53.  复原阀螺母:reboundvalve nut
54.  螺母(支柱总成用):nut
55.  橡胶衬套总成:rubberbush assembly
56.  缓冲软垫(尼龙):reboundstopper
57.  缓冲块:jouncebumper
58.  防尘罩:dustcover
59.  防尘盖(悬架支柱上部用):dustcover cap
60.  弹簧用软垫:springcushion
43
发表于 2024-1-2 13:42:07 | 显示全部楼层
感谢分享,新年快乐
GMT+8, 2026-11-4 18:36 , Processed in 0.030776 second(s), 6 queries , Gzip On, Redis On.
