查看: 1310|回复: 2
IEC 62561-7:2018 LPSC Part 7: Requirements for earthing enhancing compounds
发表于 2018-1-30 21:51:43 | 显示全部楼层 |阅读模式
IEC 62561-7:2018 Lightning protection system components (LPSC) - Part 7: Requirements for earthing enhancing compounds
IEC 62561-7:2018 specifies the requirements and tests for earthing enhancing compounds producing low resistance of an earth termination system.
This second edition cancels and replaces the first edition, published in 2011. This edition constitutes a technical revision.
a) information concerning the execution of the test for the determination of the resistivity in 5.4.3;
b) addition of Annex A for the assessment of the corrosion load.
Publication date        2018-01-25
Edition        2.0
Available language(s)        English/French
TC/SC        TC 81 - Lightning protectionrss
ICS        29.020 - Electrical engineering in general
91.120.40 - Lightning protection
Stability date          2022
发表于 2020-3-10 09:14:07 来自手机 | 显示全部楼层
发表于 2020-6-17 07:53:51 | 显示全部楼层
谢谢分享!!!
GMT+8, 2024-6-26 23:54 , Processed in 0.022949 second(s), 6 queries , Gzip On, Redis On.
