查看: 2662|回复: 16
IEC 60317-3-2011 155级聚酯漆包铜圆线
发表于 2024-5-17 08:46:37 | 显示全部楼层 |阅读模式
认证检测
分类: 新闻法规&基础知识
Specifications for particular types of winding wires –
Part 3: Polyester enamelled round copper wire, class 155
1 Scope
This part of IEC 6031 7 specifies the requirements of enamelled round copper winding wire of
class 1 55 with a sole coating based on polyester resin, which may be modified provided it
retains the chemical identity of the original resin and meets all specified wire requirements.
NOTE A modified resin is a resin that has undergone a chemical change, or contains one or more additives to
enhance certain performance or application characteristics.
Class 1 55 is a thermal class that requires a minimum temperature index of 1 55 and a heat
shock temperature of at least 1 75 °C.
The temperature in degrees Celsius corresponding to the temperature index is not necessarily
that at which it is recommended that the wire be operated and this will depend on many
factors, including the type of equipment involved.
The range of nominal conductor diameters covered by this standard is as follows:
– grade 1 : 0,020 mm up to and including 3,1 50 mm;
– grade 2: 0,020 mm up to and including 5,000 mm.
The nominal conductor diameters are specified in Clause 4 of IEC 6031 7-0-1 .
2 Normative references
The following referenced documents are indispensable for the application of this document.
For dated references, only the edition cited applies. For undated references, the latest edition
of the referenced document (including any amendments) applies.
IEC 6031 7-0-1 :2008, Specifications for particular types of winding wires – Part 0-1: General
requirements – Enamelled round copper wire
3 Definitions and general notes on methods of test and appearance
3.1 Definitions and general notes on methods of test
For definitions and general notes on methods of test, see Clause 3 Subclauses 3.1 and 3.2 of
IEC 6031 7-0-1 .
In case of inconsistencies between IEC 6031 7-0-1 and this standard, IEC 6031 7-3 shall
prevail.
IEC 60317-3-2011 155级聚酯漆包铜圆线.pdf
1.3 MB, 下载次数: 12
 楼主| 发表于 2024-5-20 08:38:18 | 显示全部楼层
 楼主| 发表于 2024-5-20 08:38:34 | 显示全部楼层
GMT+8, 2026-11-24 17:30 , Processed in 0.033538 second(s), 9 queries , Gzip On, Redis On.
