查看: 2760|回复: 15
(原版)ASTM Standards F 1852 - 14
发表于 2024-6-24 16:26:56 | 显示全部楼层 |阅读模式
认证检测
分类: 机械五金
Standard Specification for “Twist Off” Type Tension Control Structural Bolt/Nut/Washer Assemblies, Steel, Heat Treated, 120/105 ksi Minimum Tensile Strength
This standard is issued under the fixed designation F1852; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon (´) indicates an editorial change since the last revision or reapproval.
ASTM Standards F 1852 - 14.pdf
770.15 KB, 下载次数: 3
原版美标认证
发表于 2024-6-25 09:27:26 | 显示全部楼层
Thanks for sharing
GMT+8, 2026-11-24 19:09 , Processed in 0.068046 second(s), 8 queries , Gzip On, Redis On.
