查看: 2903|回复: 10
JESD22标准大全
发表于 2024-7-1 16:01:27 | 显示全部楼层 |阅读模式
附件为JESD22标准大全,供半导体同仁参考,谢谢!
DOC TypeQtyDescriptionDOC TypeQtyDescriptionDOC TypeQty
Annex (Annexes for JESD21-C)1该表简要描述了与其前身JESD21C版本26相比,对此标准JESD21-C版本27所做的更改。JESD (JEDEC Standards)362
PS- (Performance Standards)3
CO- (Carrier Outlines) 35载具轮廓尺寸:各种Package适用的Magazine,Tray,Carrier ,TubeJIG (Joint Industry Guide)2
PSRAM (3.8 Pseudostatic Random Access Memory)1
CS- (Carrier Standards) 8JM (JEDEC Manual)7
RDF (Registration Data Format)1
DG- (Design Guideline)17各种Package  Design GuideJP (Joint Publication)2
ROM (3.2 Read Only Memory)2
DIMM (DIMM Index Page) 1Dual-Inline-Memory-Modules双列直插式存储模块相关JS (Joint Standard)6
SDRAM (3.11 Synchronous Dynamic Random Access Memory)16
DO- (Diode Outlines) 19二极管轮廓尺寸MCP (3.12 Multi Chip Packages)4
SO- (Socket Outlines)22
DR- (Design Registration)6各种Package  Design RequirementMO- (Microelectronic Outlines)326
SPD (4.1.2 Serial Presence Detect)24
DRAM (3.9 Dynamic Random Access Memory)6
MODULE (4, 4.2, 4.3, 4.4, 4.5, 4.6, 4.7, 4.20 Modules)119
SPP- (Standard Practices and Procedures)25
EEPROM (3.5 Electrically Erasable Programmable Read Only  Memory) 4
MPDRAM (3.10 Multiport Dynamic Random Access Memory)5
SRAM (3.7 Static Random Access Memory)11
EIA (EIA Standards) 10电子工业协会标准Dynamic  Random Access Memory)5
TENTSTD (Tentative Standards)2
EPROM (3.4 Erasable Programmable Read Only Memory)3
MS- (Microelectronic Standards)34
TS- (Transistor Standards)5
GS- (Gauge Standards)10
NVRAM (3.6 Nonvolatile Random Access Memory)2
UO- (Uncased Outlines)2
J-STD- (Joint IPC/JEDEC Standards)8
PR (Preliminary Release for JESD21-C)8
US- (Uncased Standards)1
JEB (JEDEC Engineering Bulletins) 8
PROM (3.3 Programmable Read Only Memory)3
JEP (JEDEC Publications)97
JESD22标准.zip
343.73 KB, 下载次数: 47
JESD22标准
参与人数 1品质币 +1 收起 理由
AElarry + 1 大家不要下载了,都是一个简单的标准介绍,.
77
发表于 2024-12-22 21:08:01 | 显示全部楼层
发表于 2025-3-3 09:26:11 | 显示全部楼层
GMT+8, 2026-11-24 18:08 , Processed in 0.035371 second(s), 9 queries , Gzip On, Redis On.
