查看: 2006|回复: 8
Australia, Ripple Injection, Ripple frequency 492Hz, 750Hz, 1050Hz
发表于 2024-7-17 10:33:07 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
Test level (% increase of 240VAC reference voltage), 5%, 10%, 15%, 20%
Ripple Injection – NSW - affected and not affected areas
ACTEWAGL Supply area- Not affected
Ausgrid Supply area- Affected
Edeavour Energy Supply area- Affected
Essential Energy Supply area- Not affected
See map 1
See map 2
Ripple Injection – NSW - affected areas
Map 1 –Sydney, Central Coast, Newcastle, Hunter Valley
Note: Although all of Sydney is affected,
the worse areas are The Northern
Beaches (Dee Why, Manly, etc.), The
North Shore (Chatswood, etc.) and
Sutherland shire (Cronulla, Miranda,
etc.)
Map 2 –Wollongong, Nowra, Penrith, Windsor, Blue Mountains
Ripple Injection – Queensland - affected areas
Not affected
Not affected
Only a small part of Southeast
Queensland affected
See mapbelow
Ripple affected areas in Australia.pdf
464.18 KB, 下载次数: 2
售价: 30 品质币  [记录]
发表于 2024-7-18 11:08:44 | 显示全部楼层
谢谢分享  全英文 看看有点难度
GMT+8, 2026-11-24 17:37 , Processed in 0.036562 second(s), 9 queries , Gzip On, Redis On.
