查看: 11954|回复: 4
Supply Flexible Cord-AS/NZS 3191,AS/NZS 60227.5:2003,AS/NZS 60245.4-连接导线
管理员
发表于 2017-8-7 17:46:45 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
An electrical cord which —
(a) is unscreened and flexible;
(b) is designed for use at low voltage;
(c) consists of two or three elastomer or PVC insulated cores of multistrand construction;
(d) has a cross-sectional area of each conductor not exceeding 2.5 mm² ; and
(e) has for other than tinsel cords, individual wire strandings not exceeding —
    (i) 0.21 mm for conductor sizes up to 1 mm²; or
    (ii) 0.26 mm for conductor sizes exceeding 1 mm²;
but DOEs not include —
(f) a flexible cord directly connected to equipment or approved non-rewirable accessories which is marked in accordance with the CENELEC HAR marking scheme for flexible cords.
Class Specification:
All types: AS/NZS 3191 or
PVC insulated type: AS/NZS 60227.5 or
Rubber type: AS/NZS 60245.4
GMT+8, 2026-11-5 03:01 , Processed in 0.020702 second(s), 7 queries , Gzip On, Redis On.
