查看: 2266|回复: 19
IATF Rule 6 exam notification
发表于 2024-10-3 07:07:15 | 显示全部楼层 |阅读模式
Hello xxxxx
This email was automatically generatedby the Auditor Development Process website to support you in maintaining yourauditor qualification or non-auditor recognition in the IATF scheme.
The Rules 6 Training module is nowavailable on your IATF ADP dashboard. Upon completion of the training, the corresponding Test of Understandingwill unlock.  You must achieve a score of80% to pass the test and will have up to four total attempts (initial attemptand up to three retakes).  The test ISOpen book and not timed or proctored. Retakes will be provided automatically upon failure.
In CB Communiqué #2024-002, the IATF mandated that "all IATF 16949 third-partyaudits shall be conducted in accordance with Rules 6 effective 1 January2025."  Therefore, all auditors mustsuccessfully complete this training and test requirement before being eligibleto conduct audits in 2025 and beyond. All qualified non-auditors are similarly required to complete theserequirements prior to conducting any scheme-related activities in 2025 andbeyond.
IMPACT ON THE QUALIFICATION PROCESS:
If you are a new auditor candidate andhave not yet completed your ADP prerequisites, you are required to successfullycomplete this training and test prior to applying to attend any 4-Day Trainingclass in 2025 or beyond.  (New AuditorTraining classes conducted in 2024 will remain aligned to Rules 5.)
If you already completed your initialADP assessments but are still in the Phase 1 or Phase 2 qualification process(including retakes), please note that all ADP retake assessments and Phase 2evaluation activities conducted in 2024 will be aligned to Rules 5, and thosebeginning in 2025 will be aligned to Rules 6. Please consider the best timing for completion of the Rules 6 trainingrequirements to not cause any confusion about which Rules requirements applyduring any scheduled evaluation activities.
CERTIFICATE ISSUANCE:
Upon successfully completing the test,you will be issued a Rules 6 Training and Test completion certificate andautomatically granted eight (8) structured CPD hours.  The CPD hours will be granted in the calendaryear when you successfully complete the test (according to UTC/GMT time), andcannot be moved to a different year or split between multiple years.
In addition, eligible auditors andnon-auditors will receive a new identifying number upon successfully completingthis requirement, with new Qualification Certificates available through the ADPwebsite.  The new identifying number youreceive will be aligned to your current qualification status, but reflect thatyou are now eligible to conduct scheme activities aligned to Rules 6.  If you are a fully-qualified auditor (either5-ADP, 6-AUD-B, or similar), you will receive a 6-AUD-C identifying number withno fixed expiry date (subject to the ongoing qualification requirements notedin Rules 6).
MORE INFORMATION:
For more information, please consultIATF CB Communiqué #2024-002:
You will also find answers to FrequentlyAsked Questions about this Rules 6 transition on the IATF ADP Help Desk:
To access the Auditor DevelopmentProcess, please go to http://www.iatfglobaloversight.org/and click on the "Enter" button underneath the Auditor DevelopmentProcess heading.  If you have technicalissues accessing the ADP, please send a support request at https://help.iatfadp.com/.
NOTE: This email was sent automaticallyfrom an account not designed to receive email replies.  If you need support, please visit our supportportal at: https://help.iatfadp.com/en/support/home
发表于 2024-10-3 12:14:55 | 显示全部楼层
努力提高自己
GMT+8, 2026-11-5 23:06 , Processed in 0.034560 second(s), 6 queries , Gzip On, Redis On.
