查看: 2934|回复: 33
"过程“概念的陷阱
壹陆玖肆玖袋
发表于 2025-1-5 13:15:34 | 显示全部楼层 |阅读模式
Box 9.1 Pitfalls to avoid with processes
小贴士 9.1 过程要避免的陷阱
Some surprising, yet widely held, beliefs are that:
令人惊讶却又广为流传的观念是:
●  “processes” are a new concept
   “过程”是一个新概念
● “processes” have replaced “procedures”
   “过程”取代了程序
● you can’t manage both departments and processes in one organization
   你不能在一个组织中同时管理两个部门和过程
● to “transform something” means something other than to “change its form” or to “convert it” into something else
   “转化”的意思不是“改变其形式”或 “转换”为其他东西。
● all inputs to a process must be input at the start of a process
   过程的所有输入都必须在过程的开始时输入
● all outputs from a process must be output at the end of a process
   过程的所有输出必须在过程结束时输出
● any one activity cannot be part of more than one process
   任何一项活动都不能成为一个以上过程的一部分
● if a definition is in an ISO standard then it must be “right”.
   如果一个定义出现在ISO标准中,那么它一定是“正确的”
There is also a lack of appreciation of the difference between the concepts of something being “put in” from outside a process, and “taken in” from within the process – and, in the same way, something being “put out” by a process and “coming out” from the process.
此外,人们还缺乏对以下概念之间区别的认识:从过程外部“放入”的东西和从过程内部“带入”的东西 − 同样,从过程中 “带出”的东西和从过程中“取出”的东西。
        (弗雷泽, 2015)
本不互欠,想白嫖资料者,请绕开!
提供与汽车零部件制造有关的质量培训和咨询服务!
发表于 2025-1-5 13:48:38 | 显示全部楼层
发表于 2025-1-5 14:14:56 | 显示全部楼层
发表于 2025-1-5 14:53:18 | 显示全部楼层
学习了
质量专家
质量总监
发表于 2025-1-5 16:14:17 | 显示全部楼层
发表于 2025-1-5 17:42:00 | 显示全部楼层
GMT+8, 2026-11-5 21:18 , Processed in 0.029524 second(s), 6 queries , Gzip On, Redis On.
