Minitab enables you to analyze both location and dispersion effects in a 2-level factorial design. To examine dispersion effects, you must have either repeat or replicate measurements of your response.
Once you have determined your design and gathered data, you can analyze both location and dispersion models. Listed below are steps for analyzing location and dispersion models in Minitab, with options to consider at each step:
1 Calculate or define standard deviations of repeat or replicate responses (Preprocess responses). Consider whether to:
2 Analyze dispersion model (Analyze Variability). Consider whether to:
3 Analyze location model (Analyze Factorial Design). Consider:
Here is an example: A 23 factorial design with four repeats has eight experimental runs with four measurements per run. Minitab calculates the mean of the four repeats at each run, giving you a total of eight observations. The same design with four replicates has 32 experimental runs. In this case, each measurement is a distinct observation, giving you 32 observations.
