查看: 7285|回复: 25
纠正措施过程的步骤 (摘抄,个人翻译)
壹陆玖肆玖袋
发表于 2023-7-24 12:39:41 | 显示全部楼层 |阅读模式
Table 58.1 Steps in the  corrective action process
表58.1 纠正措施过程的步骤
Action
措施
Clause  10.2.1 requirement
10.2.1条款要求
  1.
Collect the nonconformity data and classify
收集不符合数据并进行分类
Reviewing and analysing
评审和分析
  2.
Conduct Pareto analysis to identify the vital few  and trivial many and evaluate the need for action
进行柏拉图分析,以确定重要的少数和琐碎的多数,并评估采取措施的必要性
  3.
Organize a diagnostic team
组建一个诊断团队
Determining the cause and extent of nonconformity  (10.2.1b)
确定原因和不符合程度(10.2.1b)
  4.
Postulate causes and test theories
推测原因并测试理论
  5.
Determine the root cause of nonconformity
确定不符合的根本原因
  6.
Determine if similar nonconformities exist or  could exist elsewhere
确定其他地方是否存在或可能存在类似的不符合的情况
  7.
Determine the effects of nonconformity and the  need for action
确定不符合要求的影响和必要措施
Implementing any action needed (10.2.1c)
执行必须的措施(10.2.1c)
  8.
Determine the action needed to prevent  nonconformity recurring
确定需要采取的措施,以防止不符合再次发生
  9.
Organize an implementation team
组建一个执行团队
  10.
Create or choose the conditions which will ensure  effective implementation
创造或选择能确保有效实施的条件
  11.
Implement the agreed action
实施商定的措施
  12.
Record the nature of the nonconformities
记录不符合的性质
Retain documented information (10.2.2)
保留文件化信息(10.2.2)
  13.
Record the results of Pareto analysis
记录柏拉图分析结果
  14.
Record the causes of nonconformity
记录不符合原因
  15.
Record the criteria for determining severity or  priority
记录确定严重度或优先级的准则
  16.
Record the proposed actions to be taken
记录采取的建议措施
  17.
Record the actions actually taken
记录实际采取的措施
  18.
Record the results of actions taken
记录采取措施的结果
  19.
Assess the actions taken and determine if they  were those required to be taken
评估所采取的措施,并确定这些措施是否是所需采取的行动
Reviewing corrective actions (10.2.1.d)
评审纠正措施(10.2.1d)
20.
Determine whether the actions were performed in  the best way
确定执行的措施是否是最佳方法
  21.
Determine whether the nonconformity has recurred
确定不符合是否复发
  22.
If nonconformity has recurred repeat steps 1–22
如果不符合复发,重复1−22步骤
23.
Review risk assessments and opportunities and  update if necessary
评审风险评估和机遇,必要时进行更新
Update risks and opportunities determined during  planning (10.2.1e)
更新策划期间确定的风险和机遇(10.2.1e)
本不互欠,想白嫖资料者,请绕开!
提供与汽车零部件制造有关的质量培训和咨询服务!
149
发表于 2023-7-24 17:24:25 | 显示全部楼层
非常感谢楼主无私分享资料
GMT+8, 2026-11-5 19:52 , Processed in 0.044911 second(s), 6 queries , Gzip On, Redis On.
