查看: 3299|回复: 9
GMW 14872 循环腐蚀试验_2006 Cyclic Corrosion Laboratory Test
发表于 2023-12-5 09:11:53 | 显示全部楼层 |阅读模式
GMW 14872 循环腐蚀试验_2006.pdf
1.1 Purpose. This procedure describes an accelerated laboratory corrosion test method to evaluate assemblies and components. The test procedure provides a combination of cyclic conditions (salt solution, various temperatures, humidity, and ambient environment) to accelerate metallic corrosion. The procedure is effective for evaluating a variety of corrosion mechanisms, such as general, galvanic, crevice, etc. The test exposure/conditions can be individually tailored to achieve any desired level of corrosion exposure.
Also, synergistic effects due to temperature, mechanical and electrical cycling along with other stresses can be comprehended by this test. See Deviations Section, which after the ppendices, for typical modifications.
654.23 KB, 下载次数: 10
售价: 30 品质币  [记录]
GMT+8, 2026-11-6 02:19 , Processed in 0.025900 second(s), 8 queries , Gzip On, Redis On.
