Six Sigma > Process Report > Reports
Allows you to choose which process reports you want to generate.
Default Reports: By default, Minitab displays only the first two reports.
Report 1: Executive Summary: Check to produce an Executive Summary Report. You can include demographic information in this report.
Report 2: Process Capability: Check to produce a Process Capability Report.
Additional Reports
Report 3: Process Statistics: Check to produce a Process Statistics Report.
Report 4: Cumulative Statistics: Check to produce a Cumulative Statistics Report.
Report 5: Cumulative Benchmarks: Check to produce a Cumulative Benchmarks Report.
Report 6: Performance Diagnostics: Check to produce a Performance Diagnostics Report.
Send selected reports to default printer: Check to automatically print (rather than viewing them on-screen) all reports you have requested. The reports are sent to the default printer as defined in the Windows control panel. Choose File > Print Setup to change the default printer.
